No signal ? | SatelliteGuys.US
No signal ?
Kraven
Resident Bozo
11,917
2,941
Northern, VT
Fellas... Late last fall i purchased a 222k and 612 off the SG classified. Yesterday I swung the 39" dish to 119w, connected a new line to the LNB's circ. output and confirmed reception off all the pay channels on the S9. Connect the 612 and no signal? I connected the feed to the diplexor first, then to each input 1 and 2. The dish is aimed properly and my FTA box gets the signal but not the 612. Reconnected the line to the S9 and confirmed the signal is there.
Thoughts?
Cheers, K
Did you re run your check switch? Anytime you move a dish , change to another dish etc, you have to run a check switch and save it to the matrix for the receiver to work .
Hmmm....never bothered runing a check switch since the receiver was directly connected to a single output LNB.
Try it tonight when I get in.
Cheers, K
Dish DVR Service and Protection Plan
DPP Quad + DPP Separators
