Hello All,
I'm a newbe to the forums with an issue I hope someone else has seen or have. Dish Network seems to think I'm the subscriber with this issue. It's been going on since August of 2007 and Dish Network has failed to resolve it.
This problem is isolated to FOX Detroit (WJBK) and occurs on all of my DISH recievers / DVRS (301, 510 & 625). According to the information I've been provided by Dish Network technical staff as well as my local FOX station, over the past summer, Dish Network implemented some changes to the way they broadcast the local signals. This has resulted in sporadic bad picture quality for channels 8033 and 2 and has also caused the loss of the stereo audio signal. All broadcast on those channels are now mono (FOX 2 WJBK only). Every other station appears to be coming in normally.
These are standard definition recievers and does not involve HD signals.
I called Dish Support on this for the first time in late July or early August time frame. I was told at that time that this has been a known problem since early July and Dish Network was working on it. After several weeks without a fix, I called back and was told I should call my local FOX station for a resolution. I talked to our local Detroit FOX station management. They told me that they are aware of the problem and it can only be resolved by Dish Network. According to the engineer at FOX-2 Detroit, Dish went from a Fibre broadcast signal to an over-the-air antenna signal during the summer of 2007 in an effort to cut cost.
I can receive stereo audio if I by-pass DISH and go with an antenna hook up, but the picutre quality sucks and I obviously loose my DVR capability. This also proves that the local FOX station is broadcasting in stereo.
Has anyone else experienced this or knows of this issue? Any helpful info would be greatly appreciated.
Mark
Mark
