I recently installed my OTA antenna. The installation isn't complete yet, as I need to get a taller ladder to get the antenna up higher, so I'm sure that will be "some" of my problems.
I currently have the antenna signal combined with the satellite signal using a D920 RCA diplexer and then being separated at the receiver. I'm using a DTC-100 (old school, I know
). The antenna is a VU-120 XR.
I'm in Bloomington, IN and am trying to get the Indianapolis HD channels. I am currently able to receive Ch 8, CBS, which is the ONLY VHF HD channel coming out of Indianapolis. Without tweaking the pointing and height, I'm getting about a 50 signal strength. Picture looks good, etc...
However, I can't get ABC, NBC, or Fox at all. I can get ABC and NBC in on analog, however, but they're very snowy. The analog versions of those channels are all on VHF, except fox which is on UHF on analog also.
Also, I DO get the local PBS, and pax/worship/etc (WTIU)... channels. Strangely enough, WTIU and pax are on UHF. They don't come in very well, and often pixelate. Those two digital stations are also in a different direction. about 30 degrees east of the indianapolis stations that I want. So I could probably improve those stations reception by reaiming, but I don't care about getting them
Anyway, so it seems that I have a problem with UHF. I'm wondering if the diplexers could be a problem? I'm going to try running a straight through connection tonight, but if that's not it, I don't have a clue to what to look at next, besides getting the antenna up higher.
If you have anything that I might have overlooked, that would be great!
