No Video on TV2 | SatelliteGuys.US
No Video on TV2
Petwanel
22
I just got Dish installed on Sunday. I made what I thought was a slight change and now need your help. I have a 625 in my bedroom which also serves my game room TV (an old ctr tv) as TV2. The installer made channel 60 the display channel. It worked fine. Yesterday I took out the crt tv from the game room and replaced it with a Pioneer Elite 720p Rear projection. I connected the Dish coaxial cable to the Antenna input of the Pioneer Elite but I cannot keep any TV signal at all. Can anyone help me with this problem. It will be greatly appreciated.
Check and see if your new TV is still in Cable mode. Channel 60 is is off air mode.. All new TV's come in Cable mode and won't see channel 60 off air.. OR you can change the modulator settings on your 625 to reflect a cable channel 73 or above in cable mode..
also check to make sure its connected to the "analog cable" input and not a "digital cable" input. ive noticed some of the newer tvs with inputs marked that way, and it doesnt work on the "digital cable" input.
Thanks very much. The TV was in cable mode. I corrected that problem and the tv works fine now.
HD locals on satellite vs. OTA
Dish HD, suggestions?
