norsat 8115, dual feedhorn,microhd | SatelliteGuys.US
solrackm
26
2
just received two norsat lnbs with a chapperal dual feedhorn, my question is how do I connect the two lnbs to the micro receiver since it only has one lnb input?
I think he has a Chaparrel Dual C-Band LNB?? If so I WOULD RECCOMEND A 4X1 DISEqC Multi switch in case you want to add a KU Dish at a later date!
is there a particular brand and model# multiswitch I should get?
found a dmsi multiswitch in the closet, both polarities are working.
Good choice. That's what I roll with on a 10 foot seen better days Sami. It's what did the trick for BYU.
Openbox S9 has no HDMI output
need help aiming my new dish
