not enough channels | SatelliteGuys.US
not enough channels
travis69
6
viewsat xtreme,fortec star 90cm,stab hh 90,invacom quad lnb
having troubles getting channels,get some channels can't get all the free channels.example amc 4 kuil tv fox64 getting 90 quailty but don't get any other channels on amc 4.any help or suggestions would help.thanks.
do i need a bigger dish or a better lnb.
KUIL is VERY powerful, if thats all you're getting you may need to tweak your elevation/azimuth a little.
I would remove the motor and any switches then see what kind of signal quality you get with a fixed dish. After you have the satellite stored only then put the motor back on again.......
RTN programing on G10R
New to the FTA Game
