Not Getting All HD Feeds! | SatelliteGuys.US
hjenssen
14
I have the oval 5 LNB Dish. I get some of the HD feeds but not all of them.
I don't have the bubble in the pole perfect. It's about 1/4 inch off.
The feeds that I receive are very clear.
Does the bubble have to be perfect or is it the dish adjustment itself?
Herb
Herb
First off, there was an issue with some of the hd channels this morning, CNN and some others. As to the bubble level, don't rely on it being accurate. A post level is a better way to go.
Fully agree with the suggestion for using using the post level. That said, if the mast isn't plumb to start with you are in for a very rough time maximizing your signals across all of the birds and it will continue to cause you problems in the future.
too good to be true?
D12 Autotune Malfunction
