Now using Firefox with one small flaw | SatelliteGuys.US
Not open for further replies.
stanleyjohn
1,892
30
south/central Ct,USA
Ok Satelliteguy Geeks!see if you can help me out.Now using Firefox (latest ver) over IE and finding a little problem using it on satelliteguys.Seems that the small icons are not loading correctly!see Pics.IE works ok!Just wondering if you ever seen this problem before.Other than this problem all else seems to be working fine. Thanks! Stan
I'm using FireFox with out any problems. I say check your plugins and FF to make sure you have the latest.
Check whether you are allowing sites to use their own fonts. Click Preferences > Content > Advanced and make sure "Allow pages to use their own fonts, instead of my selections" is checked. If that's ok, type about:config in a new tab. Tell it you'll be careful. In search box type: gfx and make sure gfx.downloadable_fonts.enabled is set to true.
Thanks! Did what you said about fonts and problem fixed.
"Members helping members since 2003", or so I've been told... ;)
SatGuys Reader crashing
Search Index Being Rebuilt
