Does anyone know how many D12's I can use on a reverse band DSWM LNB?
Will it support 13, 8 or none
I was about to say that, but then thought Stuart said it was actually the DSWM-30 multiswitch that the D12 wouldn't work at all with.According to Stuart Sweet it won't work at all.
Up to 13 from what I understand ...
But, more importantly why would you want to with the SD transition coming this year?
The SD only D12 will be obsolete soon ...
Sent from my LM-V405 using Tapatalk
Because I got a hotel I'm supposed to upgrade.
They had a fire, got guests moving back in and I don't have the HD equipment yet.
What was lost in the fire if the D12's were not?
Ok so I did an install today with D12 and SWM30.
I have 24 receivers on a DSWM30. 12 on each leg with 12 H25 and 12 D12
I got 8 of the D12's working on the DSWM.
Going out tomorrow to switch out the rest of the D12 to H25.
However I can confirm it will work. I think the D12 needs to be on the first 8 DSWM channels of a SWM13.
I'm assuming it works like the H20, and sees the DSWM as an old school SWM. The way the SWM protocol works the receiver asks for a particular frequency, and the SWM either accepts that or not. Since the H20 (and D12) only know about the 8 original frequencies, that's all they can ask for. So they aren't grabbing the first eight, they're grabbing the original 8, and not the new frequencies that are in between the existing ones - only newer stuff that knows about the DSWM can ask for those.
If you mixed and matched D12s and H25s unless you can somehow guarantee the D12s will start up first and grab the channels they want before the H25s can, some of the D12s may be SOL.
I always thought that the newer hardware should request the new channels first, to better work with the older stuff that doesn't know about DSWM but Directv never listens to my good ideas![]()
The real question is what ever happened to SWM accepting 22 channels
Limited time offer
