Odd changes: Resolution Settings Reset | SatelliteGuys.US
nhl66pens
25
Has anyone noticed a problem in the last 3 or 4 days? I have 4 TV's 2 of which are HD and all are connected to DirecTV. Tuesday evening, I went to watch one of the HD TV's and the screen resolution had been reset to 480 and the Guide appeared to have shifted to the right. I went to the HD TV upstairs and it appeared the same thing had happened. I've been with DirecTv for years and have had 1 HD TV for almost 5 years now and never have had anything like this happen. I reset the tv type and resolution but the Guide still appears to be slow and with a different font. Thanks for any replies.
Rob
Rob
NHL,
You didn't mention what rec's you are using, but it's possible that they received an update that caused this, that could be corrected with the next one. Are both these TV's using the same type rec's ?
Jimbo
Thanks, we have the same receiver on both hd tv's but I can't remember the type.
OTA signal strength on HR20
HD & Locals screen formatting options
