I am having an odd problem with an Openbox S9. I have four dishes connected to the S9 with a DiSEqC
switch. The receiver simply quits receiving a signal on all satellite and you get a "no signal". After you change channels with the remote a while it all comes back for a few minutes then it quits receiving again. No USB drives are plugged in. A master reset does not make the problem go away. The only way to fix it, is to load the software (flash) again. I have had to do this twice in the last 3 months. I am using the 12-2 software. Since it never gave me problems like this before, I'm wondering what's going on. Anybody got any thoughts?
Gray
Gray
