Odd tp's only | SatelliteGuys.US
Odd tp's only
1ADAM12
576
10-6 Gas Pumps
I could not get DN to clear my DN 500 dish from power lines. I moved it myself. I get good signal on 110 and 119 but only get odd numbered tp's.
Is it possible that I have LNB's both looking at wrong sats, criss crossed?
Check switch shows SW21 and only odd.
Also is 110 tp 22 conus or spot?
I have run across this problem a couple times over the years, and it has always been a bad cable, connector, or end. There might be other issues, but I would check your cables.
Dish Network Cancellation Billing
commercials for free HD
