Offset Dish with round arm (Old BJ HomeSat dish), need compatible LNB Holder | SatelliteGuys.US
dsmith0429
470
195
Lake Placid, FL
Anyone know where to find a compatible LNB holder for an old BJ HomeSat dish? This dish has a round arm instead of square or rectangular arm like most dishes. Also the 2 support arms mount on the lnb holder as well. Or is there an adapter that can be added to change the end to accept current universal lnb holders? Would like to try and possibly use this dish for a small dish c-band project in the future. Has anyone tried this? Thanks!
- a picture would help
- I'd use conduit hanger brackets; about 65-cents @ Home Depot
- dish is WAY too small (<36" Ku?) to use for C-band
That is not so difficult to make something like this. Easy to attach to round pipe. Costs almost nothing. Perhaps you even have all needed parts in your garage.
I would not bother trying a Micro C Band with a Bob Jone - it's just too small
I think Atlanta DTH was dish supplier - might want to contact them, never know.
Ray Dolby R.I.P.
Lost 99w AKA.....
