Ok, got a problem with my DP311 | SatelliteGuys.US
ioxmo
3
Hello, everyone... been a while, but I'm back with a problem.
I have two TVs, both with Dish DP311 receivers. The main one works fine, but the other one quit working after a power outage. This has happened before... I'd just unplug and plug it back in, and it'd somehow work...
However, this time it won't. I let the status thing check (1 or 8) and there's a red box with a X in it under 119 and 110. Could it have something to do with the cable?
Any help would be appreciated. :)
Obviously it is not seeing the SATs. Do you have the home protection plan? If so, schedule a service call. If the cables are bad, they can replace them. In addition, your dish could be out of whack and needs to re re-aligned.
Hope this helps....
try other receiver in same room and see if it has same problem. also make sure wire from dish is on the satellite input and not the antenna input.
E* Tech Support Getting Better
Basic Problem New TV receiver 322
