*OK* PLEASE HELP A DUMMY RECORD ON ONE CH AND WATCH ANOTHER! | SatelliteGuys.US
supermod38
111
central, ny
:confused: I guess i am older than i thought, when i schedule a program to record and the time comes to record it the screen comes up to change the ch or cancel the recording. this means i cannot record on one ch and watch another:eek:
I know it is just me, not knowing how to set it up in the MENU..................I need some help here, but please type very slow so i can understand your instructions.
my eqip;
1000.4 dish
722K only using one TV
211K
I was born two days after DIRT was invented!!:D
Since you just have one TV, put the 722K in single mode, which will default recording to TV2 tuner. Open right front panel door, press Mode button...light under single box.
Thank you, Thank you, Thank you, Thank you,
I was trying to do that in the MENU:yikes
I totally forgot about that button behind the door (CRS)
Now that you are in Single mode you can use the picture in picture (pip) feature or just hit the swap button to instantly see whats on the other tuner.
I will go out on a limb and hope this is the 722 he is having issues with and not the 211 which can only record one sat program at a time ;)
Dishonline - Music Channels
