Ok, what am I missing? :-p | SatelliteGuys.US
CharredPC
606
Lakebay, WA
Seeing as the Winegard didn't show up today, I figured I'd mount a DTV dish onto the SG2100 and at least get it set up and ready for the Ku dish.
So, it took a little rigging to get the DTV dish onto the SG2100, but it's on there now and locked onto DTV6 / Echo 6,8. I'm using PrgDVB... what am I missing here? I don't see where to enable motor usage. Does ProgDVB have that option? My installed alternatives are the standard Twinhan software, and MyTheatre.
I know I'm being dense, and I have googled with no results.
Figured I'd just ask the experts ;)
TIA
Edit: Tried the plugin diseqcu_1.2.5; ProgDVB refused to start while the plugin was installed. Removed it, back where I started.. :confused:
Edit again: Searched the forums here (doh!) and found a plugin that works; Dixie. Now if I can just find an updated dixi.ini file that has Echo 7 etc included... PS. ProgDVB is pretty useless, as it crashes every few seconds. How annoying.
MyTheatre/Dixie is letting me switch from Dish 110 to Dish 119 (and back). Guess the setup works; now if only progDVB would.
Ok... thought either worked. But I'll try.
Edit: makes no difference. By the third time I click drive "East," as soon as it loses quality, ProgDVB crashes. Everytime. If I restart ProgDVB and continue driving East, as soon as it hits quality again- crash.
I know you love Prog, Cascade, but you're going to have to defend it pretty heavily here to save face ;)
I'll defend it too. Works perfectly here for me too, but I do not use a motor. Give RitzDVB a shot too. I believe it has the ability to move a motor.
Comments on the Digiwave DG7000 anyone?
making a tv card into a satellite tuner
