Old and New UHF Remotes | SatelliteGuys.US
akschu
10
I just picked up a 322 on ebay to replace both of my 311's and I'm finding that the uhf remote stinks. With 6' of rg6 running up to the antenna, it's still acting picky despite the remote being in the same room 20' away with line of site.
I read serveral posts on this forum that indicated that some earlier remotes got poor range and ate batteries, so I would like to know how I can tell which remote I have. If I have the old one I'll just get a new one.
Thanks,
schu
at 20' with a line of site, the little antenna with no extension should work just fine, if from that close you are having problems, i'd say you may have a bad remote...
HD channel authorization SLOWER than SD channels on 622?
Spotbeam question?
