What happens to the old broadcast towers when a station upgrades? Refurbished for other markets, trashed, sold over seas.
So no need in an updated antenna, right?The range of channels that an antenna can be tuned to generally isn't that large and with the frequencies taking big hops in wavelength, there's not much use for a lot of the old higher frequency ones.
I'm not sure what you're asking.So no need in an updated antenna, right?
Sorry harshness, I thought this thread was talking about the repack and NextGen ATSC 3.0. But while I got your attention, do you know if ATSC 3.0 will require an updated OTA antenna?I'm not sure what you're asking.
That depends uniquely on what the frequencies will be for the new stations. I'm told that they will be the same post-repack DTV frequencies that we're looking at now and they'll create new stations to lighthouse the DTV channels (packed very, very tightly). If your antenna works post-repack, it should work if and when Next Gen TV becomes the US broadcast TV standard.But while I got your attention, do you know if ATSC 3.0 will require an updated OTA antenna?
OK. Thanks harshnessThat depends uniquely on what the frequencies will be for the new stations. I'm told that they will be the same post-repack DTV frequencies that we're looking at now and they'll create new stations to lighthouse the DTV channels (packed very, very tightly). If your antenna works post-repack, it should work if and when Next Gen TV becomes the US broadcast TV standard.
The technology required to capture TV signals hasn't changed the advent of color TV (UHF was enabled in conjunction with color TV in 1952) and it won't change with Next Gen TV unless Single Frequency Network (SFN; a sophisticated cell-like technology using TV frequencies) becomes a thing. What has changed over the years is that the TV bands used to go from 44MHz to 88MHz (VHF low), 174MHz to 216MHz (VHF high) and 470MHz to 900MHz (UHF) and after the repack it gets capped at 608MHz.
This may bring some changes to basic design of future antennas (since the high frequencies are useless for TV reception) but it won't change what your existing antenna can (or cannot) receive.
I guess it bears repeating: NTSC, DTV and Next Gen TV don't use different reception antenna technologies. The signals will continue to be linearly polarized. HD and "digital" antennas were a marketing ploy to sell new antennas (whereas "color" antennas added a new band).
Huh? I was under the impression that antennas were tuned by physically changing their length (because loading isn't efficient).I guess they do it by automatic antenna tuner or they have to do the manually tune the antenna?
I recall reading somewhere that some antennas are able to be re-tuned to the new frequency. I came across this video of a helicopter being used to install a new antenna while looking for that article.
Our new broadcast antenna is online!
I made a mistake,what happens to the tv broadcast antennas?Old TV towers are almost never moved. The strength standards have changed so that refurbished towers must be re-engineered before they can be rebuilt. The cost of the dismantling, engineering and erection is not that much cheaper than a new tower.
One interesting story in Honolulu is that the land that the old tower was on was so valuable that it was smart to remove the giant self supporting tower.
Limited time offer
