Old receivers | SatelliteGuys.US
Old receivers
alpls24547
Tennessee
Will old receivers work without reactivating? I have 4 that were last used in 2006 with cards. If not, are they worth anything?
What are they as far as model number? Most likely they are worth very little to nothing.
The receivers will need to reactivated. What are the models?
If they are still listed by DirecTV as having once been activate on your account they should be able to activate them.
New access cards may be needed.
Otherwise, they are boat anchors.
you'll need new cards at $20 a pop
otherwise you'll get 100, 200, 201, 600....thats about it
(t=which are the slates that show all the channel numbers and sports schedules)
VOD
DTV Receiver affecting other receiver in home
