Old Super Dish | SatelliteGuys.US
Old Super Dish
c2turbo
It comes with a dual lnb for fss , dbs and a single lbnf . Cant the dual be used for 118.7 some how ? How exacty is ths dual working in this setup? With a little tweaking couldnt it work? :eureka
From what I have read the 105 superdish can be modified to receive the 118.7 satellite. The 121 is not able to work.
The DP dual used will not work for the 118.7 as it is an FSS satellite. The DP dual is for DBS, they are different animals.
There is a repoint kit for the superdish that picks up the 118.7. It's very simple to use.
We repoint 121 Superdishes all the time. There are repoint kits for both the 105 and 121 superdish kits.
How to connect 722 to 2 HDTVs?
TNT HD poor picture quality
