Older Drivers | SatelliteGuys.US
Older Drivers
johan
SatelliteGuys Guru
134
28
holland
Hallo members .
does ore are their older drivers fore the TBS5927 ,
and so yes ; where can i find them.
Mvg
Lets try.
Magic Static was right.
Let's try the 1.0.0.3.
when i want to install a driver on my Thinkpad t40 it fails.
is intended for the TBS 5927
Help help.
I need a driver for my Thinkpad t40 and the TBS5927....
None of the drivers work.
installation fails.
The driver is installed in two steps as it's two drivers. Install the first step and restart the computer. Then it sees the second part and you can then install the rest of the drivers.
Ow, oke.
Can you : Magic Static show me which one I need to install first.
what i see is this;
tbs 5927-x64 file
tbs 5927-x86 file
TBS-5927 driver application
