On Celing mounted rear speakers? | SatelliteGuys.US
lakebum431
17,128
5,098
Norris, TN
I'm looking for some good speakers that I can mount on the ceiling to use as rear speakers. Most of the good branded speakers are made to be stand mounted or wall mounted for the rears. Does anyone have a good recommendation? Thanks in advance!
rear speakers
the only thing I could recommend for surface mounting would be some Infinity 150 or 160's or the RBH R-1's, I would lean to the Infinity's, unless you have $2000 to blow
Installing DVD Recorder to my system question
Which of these two projectors?
