On Demand question | SatelliteGuys.US
On Demand question
comcastsucks
43
I have a Linksys WPN824v2 wireless router. Can I use this wireless router with powerline adapters, or do I have to use a non-wireless router? I don't want to go with the wireless solution as I can forsee too many problems with setup and speed,
Also, are the kits DirecTv sells any good, or can I do better (faster, etc) with something I buy elsewhere? Any recommendations on a good brand/model to use with my router?
The powerline ones directv sells work fine for VOD. They might not work very well for multi room viewing. Depends a lot on how well they work in your home.
The "85Mb/s" should be taken with a grain of salt. You'd get something near that speed if both units were plugged into the same outlet and you sent data using a protocol that the directv boxes dont use.
Realistically, you'll get somewhere between 10-15 and 20-30Mb/s of throughput, and it may or may not be variable/inconsistent based on interference and other issues.
HR-20 audio feedback, functional or not??
r22 and hd and Directv
