One cable in, 2 boxes, 4 tvs | SatelliteGuys.US
j_met
91
East TX
I just bought a new house. The people before me had cable. They had the main cable dropped in the a/c closet connected to a reg 4 way splitter. Each cable ran to a different room and connected to the cable wall box.
My current setup is the HR-34 Genie with 1 mini client. What I want to do is have 2 tvs per box. 2 tvs running off the genie and 2 tvs running off the client.
How would I accomplish that? Would I need to replace the current splitter with this? - http://www.amazon.com/dp/B00BW60R68/?tag=satell01-20
Assuming no hidden splitters, you can replace the regular splitter with a swm approved one. Then use one line to the Genie and one to the client. Use the hdmi for one tv and component for the other. You could also get hdmi splitters instead which would alleviate any potential issue with HDCP problems. You do know that you would have to watch the same programming on the common tvs, yes?
I was thinking about that....the 2nd tv would be located in different room though...so I would have to buy like a 25 or 50 ft component....if I didn't want to do tat, my only other option is to get another client for the 3rd tv?
Yes, or get a rvu enabled tv, or another receiver/dvr.
Wireless Genie Client
DirecTV Genie / Client Problem
