Windows 7 Professional.
This problem started this on Monday. It has happened twice now with two new drives that were cloned from original that remains trouble free.
I have several other computers that connect just fine through my router/cable modem. The problem computer still sees other computers on my network.
I thought it may be Windows firewall. Shut it down and still have the problem. I connected the problem computer directly to my Cable modem, bypassing the router and switches and it still will not connect to the internet. Tried all the windows diagnostics and it indicates there is a problem but doesn't know how to fix it because it can't determine what the problem is.
I tried restore points but the restore process failed with an unknown reason.
When this first happened, I finally reformatted the hard drive to delete everything, reconnected my original drive and cloned the new drive to a known good drive with the basic windows 7 Pro on it that I know works. The recloned drive worked until this morning when I was working with Google Earth and then it just hung and I noticed the cloud based application could no longer access the internet. Same problem!
So what's different on the drive clone from the original? I did install Photoshop CS3 in both cases to the new drive that was not on the older drive. I also downloaded Google Earth to the new drive.
I ran a complete virus scan of the drive and it turns up nothing.
I'm stumped on this one. Any ideas?
Now off to re-clone the drive again!
