Openbox clip | SatelliteGuys.US
Openbox clip
catamount
645
179
maritimes
Got some time to play!
Would anyone have a small dvr clip from openbox they could upload or send me a PM.
I'd like to see if it would play natively on my WDTV live. I'd also like to test it on VideoRedo to see if that converts it properly.
Catamount
I just copied a couple of DVR clips from the Openbox to a thumb drive and connected the drive to my WDTV Live. The WDTV Live will not even see the DVR clips, but will play the .TS (transport stream) files created when converting the DVR clips with the Ariva A200 TS Tool. I doubt that VideoRedo will do anything with the native DVR clips either, as this is NOT the Microsoft Windows Media Center DVR format.
You will have to use the TS Tool utility, available at the bottom of the page here, to convert the DVR files to .TS files before you can work with them.
Tron is right the only thing that works is the Ariva software and it converts to a .TS file, I also use ConvertXtoDvd to take the .TS file to burn to a Dvd....Blind
What is this? Encryption?
Azteca Channels on 93.0°W Gone?
