Openbox S9 8PSK | SatelliteGuys.US
Openbox S9 8PSK
Gray1
308
2
St. Louis, Missouri
Is Openbox S9 capable of DVB-S2 (8PSK)? I can't get a peep out of the Luken Mux on 137W. Can get the Alaskan channels fine.
Try this...I know on the Openbox and the Manhattan that mux you have to monkey with the frequency
Its at 4160 H 29125 but for fun change the frequency to 4165 or 4170 and see if it brings them in.
If you do a blind scan they will show up at the right info but then you have to manually change the frequency
Here is my thread about the 87W mux and a note about that 137W mux
http://www.satelliteguys.us/threads...0-mux-on-87W-with-the-6-footer?highlight=3800
Thanks for the reply..Yup I already tried that. 4160, 4165 and 4170 for 29125. Not a peep. It does not blindscan either. 65% on Alaskan..gotta be a reason somewhere.
Thanks again
I modded the SR a little to 29123. I don't know it was needed but blind scans showed that SR and I used it. 8PSK FEC 3/4
Dish is tweaked. If I move it up or down or side to side the signal falls off. Even with the dish a little off I should receive some signal..I got nothing. I am using
and older Geosatpro CK1 LNBF. Dont know if that would make a difference. I am low on the horizion maybe signal is blocked somehow. I am about to move on.
I was able to get it just fine here in Minnesota (so its low on the horizon here too)
can't now because of damn trees
Channel breaking up, what is likely the problem?
galaxy 19 transponder problem
