are they off by 600mhz or something different?I am using my Openbox with an Eagle Aspen B1 SAT STACK LNBF. L.O. is 5750, and your vertical transponder frequencies will be off.
When scanning a stacked lnb with the OpenBox, watch the progress bar. Press exit when it reaches 50%, and will save you deleting all the duplicates.
figured that. My Coolsat 8000 you could only use one LNB LO frequency so I put it as 5750 and the vertical were off by 600. At the time it was just the 4:2:2 stuff so it was kinda mootThey're off by exactly 600 MHz...
hi,will the open box s9 do ac3 like on me tv and this tv without any add ons?
Limited time offer
