I don't see a percent reading just scanning transponder what_of_what is found. Might try a reboot the T2mi tuner driver is a little buggy. Sometimes after a blind scan a reboot is required. The Tuner driver is located lib/modules/5.5.0/extra. It is avl6261.koI just installed OpenVix and it never completes a blind scan. It sticks at 99%.
You can save the noT2mi from TNAP3 and replace the driver in openvix or any image using kernel version 5.5.0 but before replacing the driver use putty and do init 4 command and the reboot command after replacing. Before doing any of that make a full backup first.
good Luck!
I guess just don't scan the transponder that hangs.It didn't fix the problem.
TNAP3:
-rwxr-xr-x 1 root root 126904 Apr 2 16:25 /lib/modules/5.5.0/extra/avl6261.ko
OpenVIX:
-rwxr-xr-x 1 root root 131496 Apr 2 16:16 /lib/modules/5.5.0/extra/avl6261.ko
It doesn't hang on TNAP3?
I don't have C-band just ku here so can't test.
No Such problems here. I'm using the latest OpenVix 5.3.019I just installed OpenVix and it never completes a blind scan. It sticks at 99%.
Doing more research I find that it's not an issue with scanning but an issue with the users patience.I picked up another Edision with TNAP 3.0 installed. I too have scanning problems with 99W. But I narrowed it down to a particular transponder. So I do a transponder scan and deselect that transponder (4174V) before doing the channel scan. That transponder also showed when scanning 97W and I had to follow the same procedure.
It doesn't hang on TNAP3 or SatDreamGr 8 or OpenPLi.
It's fun when you get older and suffer from CRS. Took me forever to remember why I couldn't get the Ku channels to scan in. Forgot I have to change the setting everybody says to leave alone. My ortho setup requires the "tone mode" to be off not Band.
Limited time offer
