Optical input cap fell off | SatelliteGuys.US
yapagaldil
57
Hello,
My optical input cap fell off from my Harmon Kardon receiver. Is there a way to fix it because my receiver is out of warranty. I don't want to spend too much on fixing it.
Thanks in advance.
Hello,
Thanks in advance.
You can often find replacements in blister packs with the optical cables. Piece of tape for now.
A cap? Do you mean the little plug that goes into unused optical connections? You can find them in many stores, fairly cheap. I would be very surprised if a product warrant actually covered those anyways.
Or do you mean the plastic housing on the actual input? I would say a little glue should fix that.
Does it exsist?
Need help buying an HDTV
