Orbital Tracker Light Satellite Meter | SatelliteGuys.US
johnny33156
44
2
I have a Orbital Tracker Light OTM500 3.0 satellite meter.
Does anyone know where I can get a new battery for this meter?
I've never used that meter but from the following link for parts it appears they are made by the same company that makes the First Strike meters and the battery may be the same in both.
If so you could try purchasing from the above link or the following link.
Good luck! :)
Reactions: harshness
I'm wondering if a local Battery Wholesale might be worth a look ?
Good luck! :)
Thank you very much. I'v been looking for that battery for two years for my meter.
Ivystoneplace.com had the battery for all FS1 signal meters. The cost was $ 29.00.
Thanks again. I have at least 40 satellites programmed into that meter.
Reactions: Jimbo and FTA4PA
