Organizing cables | SatelliteGuys.US
Organizing cables
Cookey4444
4
Salt Lake
I'm not sure exactly where to post this question so sorry if this is the wrong spot, but in case it isn't the wrong spot...
I want to run my DTV cable from the dish outside through the window and along the baseboard to the receiver on the opposite wall. The problem is that I can't find cable clips that fit the double cable used for connection from the satellite to the receiver. I would like to nail or screw the cable clips to the wall, but an adhesive or something would be ok too. Does anyone have any recommendations for me please?
You're welcome. You can find them in white too but I noticed that after a couple of years under the sun, they begin to break. I always go with the black ones.
I bought the single clips from Lowes. I would imagine they have double clips as well.
HR 24 guide
Do I need this DECA thing?
