OTA Adapter and original hopper with new interface. | SatelliteGuys.US
cool80z
PIT MEMBER
77
15
So Cal
Hello I had to replace a defective hopper 2000 and my replacement upgraded to the carbon interface. Talked to tech support and had to upgrade 2nd hopper 2000 to carbon ui via the remote trick to see each others recordings. Now my usb ota adapter will not work it searches and finds channels then pauses and the hopper reboots. They supposedly let engineering know. Is anyone else dealing with this issue? any ideas how to fix it?
I'm guessing your market has a LOT of OTA channels, like over 100? People have reported this problem and there's no solution. Well, unless you count cancelling or stopping the scan before it reaches some number (not necessarily 100).
Sent from my HTC6535LVW using Tapatalk
yes live in the Los Angeles Market and nearly 200 Digital channels.
To my knowledge, no one from Dish, i.e. "DIRT", has acknowledged this, but enough people have encountered this problem and posted about it here that some deductions were made. Again, it's not official, but I don't recall anyone in markets with 10, 20, 30, and so on channels running into this. People in larger markets with a LOT of channels have. Strangely, it would appear that not everyone gets the reboots....
You can unplug your antenna at 50 or 70 or 90 or higher. Won't matter. I've tried, constant reboots regardless. It's a crapshoot, 1x out of 10 you may get the channels to save. Good luck. I hope the new OTA adapter I've pre-ordered works better with my Wally than the old one did.
I had that happen right after I updated to Carbon. When I called tech support and they told me that my Hopper had gone bad. They sent me a new one and I hope it's OK. So far, so good.
Hopper 3 terrible HD picture
H3 Upgrade - My Story
