OTA Antenna Recommendations | SatelliteGuys.US
andyclap
11
Just got a DTV HDTV receiver. I am trying to get local OTA HDTV signals. Can anyone recommend a good (small) antenna to be used. I am only 6 miles from the broadcast location, but on anntennaweb it says that I need a medium multidirectional antenna (red). Thanks for the input.
hdtvtechno said:
I would recommend you call your local tv affiliates and ask them at what power lewel are they broadcasting at.
Some affiliates still broadcast at low power levels.
Good idea. That would throw things off a bit. Even here between DC and BALT, my sig strenth still varies depending on the time of day. ie: primetime vs any other time.--Ray
LG H20 - Conexant comes out of the closet
HD Upgrade in Detroit (5 LNB)
