OK, so after some unavoidable delays I finally installed (temporarily) my new CM4228 over the weekend, but unfortunately there was almost no improvement over my 25 y.o. RS VU-160 antenna. With either antenna I'm receiving my "local" PBS HD/SD channels (actually 35 miles away!) very well on my Sony TV but with heavy pixelation on my 622, and neither can receive the 4 other channels I'm trying to get from a different heading at about 25 miles distance. Terrain/trees are the culprit. At one time in early Feb. I received those channels very briefly on both my TV and my 811 (picked-up with auto-scan and for about a week thereafter) but since then they have been almost non-existent. My 622 installed in early May never received any of those channels, just the PBS ones. I think I'm "close" to a solution, I believe I need just a little extra push to make the difference...
I hoped the 4228 alone would be the answer. I wired the two back grids together and set it up temporarily on a mast that also holds an old inactive CB base antenna about 2' above the 4228 and the 4228 is about 10' off the ground. In this position it is about 6' lower than the VU-160 and separated by about 15'. I did not have enough RG-6 for this setup so I used two links of RG-59 with barrel connectors to get the signal to my equipment location in the basement. I know that 59 is more lossy but over the 30' length I didn't think it would matter much. I also checked ch10 - the 4228 is indeed receiving it but not nearly as well as the combination antenna. Ch 23 (analog, TV only) comes in with the 4228 a bit better than with the combination antenna. I use that channel as a test to get the antennas pointed correctly since the 4 ATSC channels I'm trying to get (24.1-24.3 and 32.2) are co-located with 23.
I'm of course planning to replace the 59 with 6 (QS?) and all new connectors, grounding blocks, etc. But I think the next step is to add a new preamp. I was planning to order the Winegard HDP-269 low-noise amp from Value Electronics ($55), but then I see the AP8700 for $85. It appears to be one step up in Winegard's line at 19 dB UHF gain vs. just 12 dB for the 269, and an even lower noise figure (2.8 vs 3.0dB). It does not however have the high overload protection capability as the 269 (93,000 vs 350,000 uV).
Do any of you have experience with the AP8700? I didn't see this specific model critiqued in the threads. Which would you choose?
Thanks in advance for any advice and BRgds...!
