OTA Broadband Question | SatelliteGuys.US
JHC
2
I just signed up with WarpSpeed in Georgetown, Texas and have a problem setting up my Netgear wireless router. Internet is on when I connect directly to the modem. I set up the router, ran the setup wizard but when I tested it the first time, it said there was no connection. I rebooted and set it up again and it said I had an internet connection but still can't access thru the router. I am running XP.
Any suggestions would be appreciated.
Thanks.
JHC
Are you using a Dynamic IP?
Set you network addresses for DHCP "optain IP auto" then plug you modem in go to network connections, double click, click support tab, click details tab and record all of that info. Then plug the router in and do the same then post the results.
