OTA Channels Disappearing? | SatelliteGuys.US
wirm
6
I've had my ViP 622 for a couple of years now, and it just recently lost almost all of my OTA channels. I know the stations are still there, and that the antenna is fine. I tried attaching the antenna directly to my TV, and the channels come in perfectly. But when I put the antenna on the receiver, it says there's no signal.
Now the only OTA channel I get on the receiver is channel 7.
Any ideas on what might be going on?
This is an oldie but goodie. Since I no longer have a 622/722, I won't be able to walk you through it, but I can tell you the problem. A Local channels setting has been changed from OFF AIR to Cable. But if I recall, it's not in a logical place in the menu. Maybe someone here knows the what and how. But, it is a SETTING problem, not hardware.
I hope you're right KAB. That sounds like an easy fix :)
For future reference though, how does one do a hard reset? Just unplug it for a minute?
I know that there's nothing wrong with the antenna(s). So hopefully it's not a hardware problem inside the receiver. I've got some shows and movies that I wouldn't want to lose if I had to replace the thing.
Yes, unplugging it is referred to as "Hard Reset". The setting KAB refers to is located under the HD setup screen.
Thanks a lot guys. I'm not sure what it was, but the Cable/Off Air/IRC/HRC switch, hard reset, and rescan fixed it.
Where did my shows go?
TMC HD
