Hi
I have a situation that has me totally stumped. I'm hoping for some expert advice. I'm afraid that at this point, any further action I take is just "shot gunning" it and will eventually make things worst (or my sanity will go and not necessarily in that order).
Here's some background:
+ CM4228 on a 5' mast mounted on the outside (eve of the house). There are some branches as well as a guy wire/cable that supports a nearby utility pole that can be considered in the direct path. It's not significant but I can't tell whether it's a factor or not
+ Dish 811 receiver
+ Experimented with a AP4800 pre-amp (see below)
+ There is a grounding block between the antenna and the receiver
Without the pre-amp, I was getting the following
KCBS ~87% (yellow UHF, 7.9mi)
KNBC ~77% (yellow UHF, 8mi)
KTLA ~71% (yellow UHF 7.9mi)
KABC ~69% (blue UHF, 7.9mi)
KCAL ~66% (yellow UHF, 7.9mi)
KFOX ~78% (violet UHF, 8.1mi)
KVCR ~66% (red UHF, 55.1mi)
KCET ~64% (violet UHF, 8.1mi)
I tried to enhance the KABC signal which when watching fast moving sequences (such as a football game), the picture pixelates and drops quite frequently. When I put the pre-amp in place, I don't see much difference (KCAL goes up to 72% but then KFOX goes down to 74%). With such a high gain amp, I expected some channels would drop as well due to xmod but none of that happened either - Yes I tried powering down the pre-amp and the picture as expected freezes then goes away
So my questions are:
1) Should I try a lower gain amp (i.e. AP4700)
2) How about raising my antenna to try to get out of the way of the obstructions
3) If I want to route the signal to another TV that will require less than a 50' cable run, can I do it without a distribution amp? If one is needed, does it have to be UHF-only (if it exists)? Any recommendation on model(s)
Any inputs would be greatly appreciated...
+ Dish 811 receiver
