OTA HD reception Chelsea/Columbiana,AL | SatelliteGuys.US
thekid1975
Hey y'all,
I am new to the board. Recently I puchased a HD tivo as a new customer with Directv. I was told (only after the unit was installed) that I cannot get any local HD channels via DTV w/ the tivo. So my question is, has anyone who lives in the Chelsea/Columbiana, AL area had any luck on getting the local HD channels OTA? If you have, please give me any tips that might help me. Thanks in advance.
I used zip 35051 for Columbiana, AL and that is in the Birmingham, AL DMA correct?
Attahced is a result of your area DT situation; and you should have no issues receiveing them with a correctly selected and installed OTA antenna. Unfortunately you have that one channel way off in another heading from the others. Maybe try one of the following below; I see one is also VHF HIGH, but you might have luck receiving it without needing a combo antenna.
Channel Master CM 4228
Winegard PR 8800
Antennas Direct DB8
Winegard HD 7084P
Channel Master CM 3678
