OTA HDTV Cable Antenna Installation | SatelliteGuys.US
  • Thread starter Thread starter dantev
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
dantev
When I run the rg6 cable from my Channel Master 4228 UHF antenna through the Directv RG6 cable. I lose the signal. I am using a Terk BMS 58 multi switch and standard diplexer. (Connecting the ant cable into the BMS 58 ant input and the diplexer at the receiver end.)
I am wondering if the BMS power is interferring with the OTA signal. When I connect the Antenna directly to the HR10-250 the signal is good but I wanted to run the install the antenna on the roof and use the exisiting cable.
The satellite signal is strong and I have checked the cable connections.
Any advice would be most appreciated.
Thanks.
Euro1080 reception
Apartment
