OTA Local HD disappear? | SatelliteGuys.US
like2watch
31
I have a ViP 622. On Sunday I attached an indoor antenna because I want to record a PBS special in HD and DISH locals are not HD for my PBS stations. I did a scan and got 25 local HD stations, looked at them, programmed to record the shows, etc. Today I went to view one of them and got the error about the signal being lost. I tried re-scanning and got zero found. I did a front panel reset and it came back up with the lost signal error. I checked the connections (hadn't touched anything) and tried moving the antenna around a bit. No luck. Called support, got "advanced" tech who knew nothing. I had deleted all the stations hoping a rescan would pick up but still getting zero.
Any ideas?
Go to menu, system setup, HDTV setup, and make sure the analog type is set to offair. If it isn't, change it and then do a rescan.
Thanks much, that did the trick. I had forgotten that I played with that setting.
Message: Losing HGTV and Food TV
Using Tivo on a Dish TV2?
