OTA with AMP will H10 power it? | SatelliteGuys.US
PBHDinSD
105
San Diego
Hi
I just got the H10 and Directv. I have a OTA with AMP left over from a Voom install. I am not getting any channels OTA.
Will the H10 supply power to the AMP?
Is there a Users manual download for the H10?
Any help will be appreciated.
Yes, the H-10 will power an OTA preamp. However, you need to use a special diplexer at the antenna side of your run that passes power for both the satellite and ota leg of the diplexer. This allows the 12v-18v power from the STB to power the amp. You will use a regular diplexer at the STB to seperate the OTA from the SAT feed.
Al
Thanks Al.
I have the diplexor that was provided by Voom, I will give it a try tonight.
The Direct TV tech replaced it. Not sure if it is supplying power or not. I am guessing not since I do not have OTA reception.
My Bad for not making sure he hooked up everything correctly.
Pat
NFLST Short Cuts?
MY NFL STSF deal
