Overdue Thanks (Mounting/Fishing/Concealing Cables) | SatelliteGuys.US
Kraven
Resident Bozo
11,917
2,941
Northern, VT
Cant find the threads but in the past several months we discussed mounting on drywall, and running cables behind the walls etc
I initially centered the TV on the wall in line with the furniture. Since I could only find one stud, the rest of the mount is secured in the drywall using 200lbs rated anchors (55" Sony HX750 is 31lbs --> this past weekend I discovered the studs are 24" aparts (the other side of the wall is concrete).
On the left side, I made a 2" x 2" hole and ran 3 HDMI cables, Cat5 and RG6 from the TV and fished to the end corner wall (6ft high corner shelving unit which contains the xbox, MicroHD etc.
A colleague (electrician) installed a power plug behind the TV.
Now EVERYTHING in concealed and looks pretty darn good. Despite the man cave looking like a play house with all the toys... the room looks awesome nonetheless!
Thanks again to those who put in their 2 cents!
Cheers, K
I've hidden as much as I could with my surround speakers but hiding the cabling for the components and front three speakers is impossible. I have Monster M2.2s " garden hose " speaker cables for the front three. Thought about covering them with that rattlesnake TechFlex so they'll look like a couple of timber rattlers coiled up behind the speakers. :D
Google's Chromecast Is Open To All, So Bring On The Streaming Apps
TV decision
