Owned Modem comcast speed upgrade any problems? | SatelliteGuys.US
daveh505@comcast.net
104
2
Las Cruces NM
In my area ,Las Cruces NM, Comcast has upgraded the speed of uploading and down loading. In the email that alrted us it has a proceedure to reboot vour system before the system can go faster. There is a place at the bottom of the dialog box to click on to check your modem to see if it is a DOCSIS3.0modem.
As I understand it my modem needs to be compliant with this standard to take advantage of the new speeds.
My question is: if my modem is not a DOCSIS3.0modem what path do I take to comply so I can use the extra speed , short of renting one from comcast. mine has been paid for in triple from not renting thiers. or is there an alternative?:confused:
This.
To confirm others opinions, you can continue to use your existing modem, but will not receive any speed upgrades via firmware. You must purchase a new modem that is d3 to utilize the new speeds. I personally dont like the zoom modems, but its all opinion, id go with either ubee or motorola
Sent from my PG06100 using Tapatalk 2
