Owner Supplied Multiswitch | SatelliteGuys.US
wtberks
Installatin Inc. is supposed to install my system tomorrow. In the installation directions, it mentions a user supplied multiswitch. I currently have a 3 lnb DirecTv dish that will be removed. Can I use the multiswitch rom that dish? If not, is there a specific switch that I should buy?
Thanks,
Bill in Long Beach
NO, you cannot use the switch that's built in to your phase 3 triple LNB DTV dish.
However, if you ordered more than 2 receivers, then VOOM installer will and is supposed to supply the multiswitch needed.
Anyone Use Terk Indoor Antennas?
Stealth -> Winegard
