Packet sniffing a ViP 722 | SatelliteGuys.US
sigmtr
81
Central IL
Oh boy, what insomnia will lead you to do... Last night I dragged out my old dual-speed hub and spliced it between my switch and the 722's Ethernet port. The laptop went on another of the hub's ports and Wireshark was fired up. I made a filter to only log things to/from the 722's MAC (hardware) address.
As with all devices on a LAN segment, there is a bit of overhead traffic. Address Resolution Protocol (ARP) requests occur when the router asks who has a certain IP address and the device responds with its MAC address. This is similar to a DNS lookup at a hardware level; it is needed to route packets to the proper device.
DNS requests are also regularly made by the 722, and just for two names:
refractor02.managed.contegix.com
DISH Network -- Home
The first request gets a "No Such Name" response.
The second resolves to 205.172.147.51
Then the receiver then goes through a series of TCP SYN/ACK/FIN exchanges with the Dish Network web server, ending in a http TCP packet that is only one frame and contains no meaningful (to me) data.
I also saw a few attempts by the receiver to SYN with an IP address that didn't result from a DNS lookup. It was 63.246.23.135, and that resolves to 63-246-23-135.contegix.com.
Interesting. And before anyone objects, it's my LAN in my house, and I can look at what's going over it if I want! ;)
sigmtr
pls post the content of that http TCP packet you found so we can try to interpret what it is doing.
yes, i could do the same thing at home but i feel lazy today. :D
Will Dish322 work with a Legacy Twin with no switch(only wnat 119)?
NBA League Pass HD showing up, not ordered.
