Pansat 1000 | SatelliteGuys.US
Pansat 1000
This assumes that it's not the ancient "BR-1000", which is an analog receiver from the early 1990s. Look for the words MPEG-2 somewhere on the receiver,
or examine the name plate for a full model number. (Are there any letters
before "1000"?)
Mike
Model 1000A
Hi, just say PANSAT 1000A Digital Satellite Receiver....
I do a automatica scan right now, but is sloww......I see if work later ....:)
Bad luck...
well, maybe have some trouble with tuner...just say 20% of level.....
I think is RIP....
if it shows 20% signal either the LNB isnt hooked up or the LO frequency iosn't correct
What kind of dish/LNB/etc do you have?
Config...
Have a Universal LNB (9750-10650) and the same config work with my TwinHan1020.....
Now check again and can read 20 % ALL the time, with cable or without cable is the same...
Transponder Blind Scan
Lnb
