pansat 2500a passsword? | SatelliteGuys.US
RLDSL
49
4
can anybody tell me the master password for a pansat 2500a?
I'm installing a new one that I bought, and whenI try to get into the installation menue, it's asking for a pasword that isn't written anywhere in the documentation.
Thanks----------Robert
Never Mind, I found it on th e net.
Thanks----Robert
I think I blew a brain gasket trying to figure out that manual :-)
Yeah, its really not worth the paper it was printed on.
I honestly didn't look at the manual for over a month after I got my PANSAT. :D
It is easier just to keep whackin buttons until I get the desired result. :eureka
default password for all menus is 0000
you can change it, although I dont reccomend it as if you forgot ti how would you get it reset ? :)
Sucess!! well sort of
kmmf fox in missoula
