Pansat 330A channels locks up | SatelliteGuys.US
csarmas
2
I have Pansat 330A receiver . Lately it start to lock up while changing channels . After several times changing channel it locks at the last channel . Picture and sound are fine but I can't change the channel . After rebooting , it works for but same thing happens again . When its locked , in remote control except power button nothing functions . Also front panel lights are flickering with all sort of gibberish charecters. I also left unpluged overnight several times nothing changed . Anybody has any suggestion ? Thank you .
Hopefully you posted this in the wrong forum.
I'm moving this to FTA and will let Iceberg deal with ya
What satellites are you pointed at? What channels does it do this on?
My problem is not certain satellites or channels and It doesn't lock on certain satellite or channel . I can wacth all of them fine . Receiver locks at one after changing several channels and doesn't do anything then I have to turn it off to reset it . It works OK for a while and same thing again
going away for 2 days....
korean programming
