Pansat 3500 and 5000 | SatelliteGuys.US
patmanpatman
9
Pansat 5000HC
Does anyone have experience with unit?
I have 1 and have it set up ...would like to tweak, almost have arc adjusted correctly.
Thanks.
Are the setups similar.. I have a 5000 understand 3500 is a great unit also. just want to compare notes.
I appreciate feedback.
Since there are similarities, does this mean files or updates to channel lists. etc. would be the same or very similar.
I have been reading up on these things, but when in doubt, ask about.
thanks much
files are different due to the software in the units
channel list editing software works the same
Thanks.
I have read up some and downloded pertinent files from satcodx then integrated then to 1 file.
Do I load this up thru gtools or the Pansat 5000 loader that uses USB cable.
Or is there a better program.
Need help with setting up coolsat4000 Pro with moter.
Can't get G3 on Viewsat VS2000
